Detailing the Underbody
I've got my body lifted from the frame. Cleaned it of all grease. Any tips on painting the engine area, floor pans and area above the gas tank. How much sanding needs to be done? I'll sandblast the floor pans? Any suggestions on paint type? Anyone painted the inside fender wells? What about areas where the sealant has flaked? Probably too many questions, Huh!
Received 6,943 Likes
2015 C2 of Year Finalist
Re: Detailing the Underbody (MRKearney)
How nice do you want it some people have the under side as nice as the top
If you just want it to look nice, then I would go to some auto shows and look for ideas.
Be careful, this can become an obsession, I know. Remember, one of these days you will cover that frame up, and no one except you (and your camera) will know how nice it looks. :)
Re: Detailing the Underbody (mapman)
Be careful, this can become an obsession, I know. Remember, one of these days you will cover that frame up, and no one except you (and your camera) will know how nice it looks. :) [/QUOTE]
:iagree:
[Modified by David68, 9:46 PM 4/18/2004]
Re: Detailing the Underbody (David68)
I used some nasty alkalic cleaner to remove all the grime from the underside, then went over it again to remove every last trace of dirt, then I cleaned it off with some IPA and painted it with POR15 and another layer off PPG Deltron black. Spraying the por is nasty, really nasty (not recommended) but I built my own fresh air system from a 3M face mask that normally accepts filter canisters, I hooked long hoses to it and I did the work outside on a hot summer day when the wind was down.
Here's the result:
Here's the result:
Here is a little obsession:
Frame and metal components - Por-15 (semi-gloss) then top coated with Rustoleum satin. Engine compartment and underside of all fiberglass except floor pans - Satin Enamel. Fiberglass floor pans - Ace Industrial Aluminum paint (to help reflect heat).
POR-15 comes in different colors. POR's only weakness is UV rays/direct sun exposure. Being that these surfaces will not be exposed to direct sun, I would just go with a color I liked and go with a single coat. Remember, bright colors will show dirt/oil. I would stick with black gloss. Gloss is more durable and easier to hose off in the future. POR also prefers going on over rusty or preped bare metal. If you plan on painting over pianted surfaces you may want to go with Eastwoods Under-carrage epoxy paint. Works great and goes on well over sanded painted surfaces. My 2 cents worth.
