COnverting to big block and hooker side mounts
Cruise-In IV Veteran
Cruise-In V Veteran
Is there a fitting problem with the BBC AFR heads and Hooker side pipes? I saw a pic of somebody having troubles with some small block heads.
On summit under technical tab, they say that you need BBC frame stands and motor mounts. What in gods green earth is a frame stand? And do big blocks have a different motor mount location? Whats the deal with the motor mounts?
And next, what kind of intakes fit under the 73 hood? The L88 hood? and the dual naca duct hood(high rise)?
Thank you for your time :cheers:
