where to get 30 amp circuit breaker
i need a 30 amp circuit breaker for the power windows in my 77 but no one around here has one with the same connectors so any help would be great
Re: where to get 30 amp circuit breaker (vette90189)
try your local dealer , if you have not come up with one by monday send me a message on this post and i will get you a part number for one , not sure the exact style is still available but i know that gm still offers at least one style that my dealer keeps in stock , thanks vette75406
Re: where to get 30 amp circuit breaker (427V8)
Since current is the issue and not voltage, I have often wondered about mounting a single phase electrical distribution box somewhere convenient, meaning also short wire runs....that leaves the back end of the car out.....
and using household a/c breakers, all clearly marked....hell with fuses...
GENE
GENE
Re: where to get 30 amp circuit breaker (mrvette)
GENE
GENE
Re: where to get 30 amp circuit breaker (rcastor426)
I went to autozone and they do not have the one with the right connector on it the one they have uses the flat slide in leads and the one I need uses the rounded ends like a glass fuse
The gm part number is 2474055 , it is discon but here are a dozen or so dealers accross the country that still have one in stock, you can go to your local dealer have them do a **** case on this part number , they will need your vin number to order it .hope this helps ,vette75406
