ZZ4 engine disapointment
I installed a ZZ4 in my 1980 back in April 2000 and was was pleased with it. I drag race with the car and it has run very consistent. 12.80s in the 1/4, with 1. 60 foot times. Last November with about 30,000 miles and 880 passes, I had 2 pistons crack their rings and lands. I replaced only the 2 bad pistons (# 3&5)and checked the others. Last weekend I did the same thing to piston #7. I will now replace all 8 with a good forged piston. Now my disapointment, the GM performance book says this engine has forged pistons part number 10159436 offset pin. Wrong the pistons in my ZZ4 are not forged. Had I known this I probably wouldn't have bought the ZZ4 but built an engine. Anyways, so much for truth in advertising.
Re: ZZ4 engine disapointment (jamiejamison)
maybe i don't know what i am talking about, but isn't 880 passes alot?
I hope you pursue this a bit farther. That is a serious accusation. When you buy a crate engine from GM you have to take on faith what they tell you is inside. Not too many people are going to tear apart a brand new engine to verify the internals. Heck, I probably wouldn't even take off the valve covers. I would take this up with whoever I bought the engine from. MJ
Re: ZZ4 engine disapointment (cmashark)
[Modified by MNJack, 12:22 PM 4/15/2004]
880 passes and you are disappointed ? :confused:
Re: ZZ4 engine disapointment (MotorHead)
He probably wouldn't have made that many if he knew his components of the engine weren't up to snuff. False advertising, plain and simple.
Re: ZZ4 engine disapointment (6318)
Pretty sure the ZZ3 was the last forged piston ZZ engine. Sounds like you're detonating if you're breaking ring lands. Ouch!
Re: ZZ4 engine disapointment (gerry72)
The ads don't mention forged pistons, just high silicon content...
http://www.paceparts.com/product.asp?0=239&1=241&3=1212
P/N 24502609
5.7L (350ci) High Output Chevrolet V8
High Output 5.7-liter engines are assembled using brand new, premium quality components. This assembly combines proven small-block components with the latest advances in engine technology, including lightweight aluminum cylinder heads, low-friction hydraulic roller tappets, and hypereutectic (high-silicon) pistons.
I am always of the theroy that if your racing a car / engine and it fails......well......what did you expect? I mean 30,000 miles and 880 passes is alot of abuse. :cheers: sounds like it was pretty damn fast too !
[Modified by flood, 12:30 PM 4/15/2004]
Re: ZZ4 engine disapointment (flood)
I was gonna say this was taken off the Salle Chevroley web-site:
Pistons: 10159436 High silicon aluminum with offset pins.
How old is your performance book?
Did GM change pistons somewhere down the line?
[Modified by 1971Ultra, 2:54 PM 4/15/2004]
[Modified by 1971Ultra, 2:56 PM 4/15/2004]
Re: ZZ4 engine disapointment (1971Ultra)
You are exactly right...my bad...
I was remembering the difference in crankshaft between the ZZ4 and RamJet (my other contender) which was forged vs cast
:rolleyes: And just why is it do you suppose that the great warranty you got with that engine is VOID IF USED FOR COMPETITION? ;) :cheers: :seeya
Re: ZZ4 engine disapointment (phxraptor)
To clearify a couple responses. The 2003 GM performance parts catalog as well as the 1999 both state in ZZ4 technical information "Pistons... 10159436 High silicon aluminum with offset pins" Now in the section CHEVY SMALL BLOCK-V8 - GROUP 0.629 PISTONS states with pictures "High Performance Pistons
Forged aluminum piatons are available in standard and oersize diametera for many high-performance Chevrolet small block V8 engines. These forged pistons will stand up to the heat and cylinder pressures in high compression engines. ......." Six piston part numbers are listed, 10159436 is one of them. Hope this clears up the mis-advertisment I state.
Yes I do think 880 passes on the strip is good, and I should expect some trouble, but broken lands on a forged piston in a 355 hp engine is is not one of them. I've alway maintained this engine well, with top oils ets.
Anyways, it will have forged pistons in the next few weeks. Thanks for all the responses.
30,000 miles and 880 passes, i know guys that drag race very seriously, and if they had a motor last that long they would buy a hundred of them. look at how much a nascar engine costs,( much more than the little ZZ4) sometimes they don't last the 500 miles in 1 race.... i think you made out pretty good with that much racing.
Re: ZZ4 engine disapointment (AGVI)
Not with that weak 1980 rear end and half shafts, would't make a single pass. With the 355 horse, I've gone thru 2 sets of posi clutches in the rear, 4 half shafts (have special builts one now) and about 20 sets of universals.
Since this is a street car also I didn't want to change to a solid rear. Wish now I had and put in the BB and a glide.
