Need GM Part Number help for oil filter bypass
I need a GM part number or aftermarket source for the part that bolts into the oil filter area that the oil filter filter spins onto. I have a 454 block but I think this part is the same for all chevy blocks???? Also, what is the proper name for this part?? Thanks
Re: Need GM Part Number help for oil filter bypass (Mr D.)
I went with a summit adaptor without the bypass, no sense sending unfilter oil into the eng.
http://store.summitracing.com/search...-2015&x=12&y=7
Re: Need GM Part Number help for oil filter bypass (Fevre)
I agree with Fevre, I don't use the bypasses either. They do send unfiltered oil through your engine when the engine is cold (thick oil)
I do however used long style filters so there's no chance of the case cracking. I stepped up to Wix HP6 style filters
Re: Need GM Part Number help for oil filter bypass (Twin_Turbo)
My engine didn't have one either when I bought it. Went to a salvage yard and got one for $5.00. If the spring is still able to move freely, it's still good. Just about all Chevy engines use this by pass system so it should be easy to find.
:flag
:flag
St. Jude Donor '05-'06
AC DELCO sells the long style filter under a new part number PF1812.
They are about $3.50 at parts stores.
