Secondary Valves - Mech or Vacuum?
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Quick question, are the secondary valves on a '70 350/300 stock carb, mechanical or vacuum operated?
Thanks,
Joe
Thanks,
Joe
Re: Secondary Valves - Mech or Vacuum? (86_RedRider)
Pretty sure those are vacuum.
If we're talking about the Quadrajet here, the secondary throttle plates are mechanical. BUT, the air valves on top open up according to the amount of air flowing through them -- that's what makes the QJet unique.
Re: Secondary Valves - Mech or Vacuum? (page62)
Actually, Holley and Barry Grant are the only manufacturers to use a vacuum secondary. All the others use an air valve, like Page says, to allow the secondary to respond. The Quadrajet is one of the best designs since it allows easy tuning on the opening. And on the Q-jet, the air valve's position also affects the secondary metering rods so the more the door is open, the more fuel is metered into the jeg. The Carter AFB and Edelbrock variants use a counter-balanced weighted door that requires mass to physically be removed (like drilling or grinding and it's awfully hard to go back once you take it off) off the counterbalance to tune the door opening. The Carter AVS and Edelbrock equivalent have an air door similar in tuning to the Quadrajet.
Don't know why everyone bangs on the Q-jet. It's nearly infinitely tuneable.
Cruise-In V Veteran
Re: Secondary Valves - Mech or Vacuum? (gerry72)
thanks. my father-in-law was asking if i could find out. he wasn't sure if they were working or not, i told him to let me drive it to find out. :D i don't think he's taken it over 60 and he hasn't accelerated fast enough either. He's only had it a little over a month now. i have actually driven it, and more and more, it makes me want to get a C3 as a stable mate for my 86.
Received 4,926 Likes
Correct as stated by the San Antonio guys :yesnod:
