Setting up a holley carb
I cant get my 4175 to idle below 1050RPM. what can i do? also where can i get some specs for the floats and stuff, i checked in my holley books and on the net and couldnt come up with anything.
Re: Setting up a holley carb (battsup)
Make certain that you don't have any vacuum leaks. It only takes a small one to screw things up and C3's have about a million places to have them.
This is what Lars posted in the tech section. https://www.corvetteforum.com/techti...=108&TopicID=3
"I cant get my 4175 to idle below 1050RPM. what can i do? also where can i get some specs for the floats and stuff, i checked in my holley books and on the net and couldnt come up with anything."
Do you mean it won't go below that or that it runs bad if below that?
Received 4,924 Likes
Plugged idle circuit or secondary throttle plate angle incorrectly set.
