Guys with amps in storage bins
Re: Guys with amps in storage bins (battsup)
you could go right to the battery, or drill a hole and install a grommet and run a wire to the frame. i think it would probably be best to go right to the battery though.
I went right to the battery I have 2 posts(side and top) for the + and -, so it was to easy to wire up. Plus going straight to the battery is the best ground you could get.
Re: Guys with amps in storage bins (cutlass44)
:withstupid:
