What exactly is a 3/4 Race cam ?!?
I've heard of 3/4 race cams before and it sounds like some "super radical gearhead" part to put in your engine. Any info. ??? :confused:
Some people refer to it as a 270-degree cam that is 3/4 of 360-degrees although there is no such thing as a 360-degree cam. Others claim that race cams are 300+ degrees of duration and cams were measured crudely at 1/2 race or 3/4 race. Is this advertised duration ? .....what about lift ? :confused:
Re: What exactly is a 3/4 Race cam ?!? (verskel)
It's an old term from back in the days when the hot engine was a flathead Ford. There were "1/4", "Lakes", "3/4" and "Full Race" grinds back then.
Nobody uses those terms anymore unless:
1. They don't know what they're talking about and they heard somebody use the term once, or,
2. They're an old-school guy who digs the Flathead Fords.
Re: What exactly is a 3/4 Race cam ?!? (The Dude)
And Mercurys.
Its a term used by someone that thinks a hot setup is a 283 with a tunnel ram, a rev kit solid lifter cam and two holley 750 DP's through stock exhaust manifolds.:) In general, a term used by posers to sound like they know what they are talking about.
The term "3/4 race" has long since been replaced by "street/strip". Both terms cover a lot of territory, anything from a little hotter than stock to a lot hotter than stock.
Re: What exactly is a 3/4 Race cam ?!? (45ACP)
And Mercurys.
And Mercurys.
Back in the "old hotrod days" the hot ticket was stuffing a 428 CobraJet into a Falcon and bench racing that it had a 3/4 cam in it.Kinda like strapping a Boeing engine on a skate board and bragging how fast it was. :lol:
From experience:
A 3/4 cam is one which runs rough, won't idle and lowers manifold vacuum used for proper C3 headlight, power brake and wiper operation.
Re: What exactly is a 3/4 Race cam ?!? (The Money Pit)
Back in the "old hotrod days" the hot ticket was stuffing a 428 CobraJet into a Falcon ...
The dude: Your wrong!:)
JCWhitney - Had 3/4 race cams listed under cams for big bore hopped up 1900+ cc VW engines. :rolleyes:
Re: What exactly is a 3/4 Race cam ?!? (gkull)
I guess the next time I pull up at a stoplight next to an "old" Beetle or Kharmann Ghia I ought to fear the power of the J.C. Whitney 3/4 race cam. :lol:
Re: What exactly is a 3/4 Race cam ?!? (triadecho)
From experience:
I'll have to remember to tell my brother that one about his 1970 1/2 Falcon 429 Super Cobra Jet. I have a feeling I'll be in for a grudge match when he's finished showing at Carlisle. :steering:
Re: What exactly is a 3/4 Race cam ?!? (Vetterodder)
Before my time. Have rarely heard it, but when used, they haven't a clue.
From the flathead Ford era which ended in 55. They were regrinding stock cams on a smaller base circle which by keeping the overall height as much as possible would increase lift, etc. They also milled the heads for more compression & the flywheel for less weight & removed as much weight as possible.
So 3/4 is somewhat generic & Vetterodder's def. "anything from a little hotter than stock to a lot hotter than stock" should be it.
According to the Crane Cams website, here is a description of a 3/4 Race Cam:
http://www.cranecams.com
Part Number: 10008 Grind Number: 282 H06
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 PERFORMANCE USAGE, GOOD MID-RANGE TORQUE AND HP, BRACKET RACING; STREET, HEAVY, ETC., AUTO TRANS W/3000+ CONVERTER, 9.5 TO 11.0 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3134 @Valve 470 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3134 @Valve 470
Rocker Arm Ratio 1.50
Cam Timing: TAPPET @---
Lift: Opens Closes ADV Duration
Intake --- --- 282 °
Exhaust --- --- 282 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 105 LBS @ 1.700 or 1 45/64
Open 273 LBS @ 1.260
Recommended RPM range with matching components
Minimum RPM 2500
Maximum RPM 5500
Valve Float 6500
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 12.0 BTDC 34.0 ABDC 101 226 °
Exhaust 44.0 BBDC 2.0 ATDC 111 226 °
[Modified by TedH, 8:40 AM 4/14/2004]
262-400 C.I. V
Part Number 99848
Minimum RPM 2500
Maximum RPM 5500
Valve Float 6500
