need advice: hood, manifold, carb & more
8th Gear
My buddy just purchased a '80 vette after returning from his tour in Iraq,
and I'd like to do a bit of research before we get started on a few projects. It's in good running condition but it's all stock .. and well, that needs to change :lol:
I've been reading through alot of posts and learned quite a bit of information, it's nice to see how helpful everyone here is. We have some previous experience with his last '79 camaro with a built 350 .. after three years of hard work, it was pushing 450hp normally aspirated with full muffled dual 2.5" exhaust; and you could still here it from 1/2 mile away :chevy :chevy
Anyways, here come the questions.
Looking around online I've only come across a few different hood options, particularly the stinger and l88 style hoods at eckler. Upon finding closeup pics of some peoples cars it appears that the stinger style hood is only a functional cowl, and that the front inlet is actually sealed; would it be feasable to cut this out and put in a screen? Or perhaps could you point out a better place to purchase a hood.
Furthermore, I'm familiar with the Edelbrock Performer RPM intake that we used on the camaro, and on posts here I've seen much referral to the "edelbrock performer," is this the same model or are there different Performer and Performer RPM models?
On that note, the carbeurator could use a little change, and this seems a tidy bit more complex with all the vaccum lines and what not, but I did see some direct replacements such as this Edelbrock (I like them as you couldn't tell.)
http://www.ecklers.com/product.asp?d...8VWQG1CL40B74C
It's a bit pricier then getting a replacement of the original or a rebuilt version, but in the end it's what the car would be happier with ... that's all that matters; my question is this: is it actually what it claims to be, a direct replacement that will fit the factory hardware and vaccum lines? And would it need an adapter plate to fit an Edelbrock Performer manifold since it's a stock replacement part (or so it says)
:rant:
I know it's a long post, but if you have any input on any of the topics mentioned it would be greatly appreciated! It'd be good to get this car started off on the right foot
:rant:
8th Gear
Re: need advice: hood, manifold, carb & more (tomservo291)
note: I just found on eckler's that for any non q-jet carb you need the adapter plate .. only $8.99
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I don't have a lot of input, but I can help a little on the manifold question.
The Performer is NOT the same as the Performer RPM. The Performer RPM will not fit under the stock 80 hood, but it sounds like you will be changing that anyway. If you plan on building up the engine, then the RPM would probably be a good choice, as long as you will be replacing the hood. There are a couple other hoods out there as well, I believe there is a "turbo" hood in Eckler's, but I haven't looked for some time. The turbo is a high rise hood and has two scoops in it. A guy I knew a few years back had fabricated a box around the air cleaner assembly and created a sort of ram air hood using the scoops in the turbo hood. Unfortunately, I don't have any designs for that hood. Sorry I couldn't help out more.
8th Gear
yea, I'm not quite so sure about that carb I posted. It's great and all, it's what I'd like to see on the car, but 750cfm seems a bit large for a 350 that will only have headers and a new intake, it will probably be some time before it gets any major work done such as better heads. What is the stock cfm of the q-jet on a 350?
Re: need advice: hood, manifold, carb & more (Captain Morgan)
If you're more concerned about the function of the hood rather than appearance, the cowl induction is actually better. It's my understanding that the highest pressure area is at the base of the windshield. This forces cold area into the L88 style cowl induction. Thie L88 hood will also permit almost any intake and carb to be used.
Gary
Gary
Re: to your carb. 750cfm is just fine for the 350 engine. You figure must came from the factory with 750 q-jets. :cheers:
Someone needs to verify this, but I think the stock '80 hood has the most clearence of all of the stock small-block hoods. Some people have gotten the RPM manifold to fit. It requires a 2" drop base air cleaner and a 2" air filter (NAPA sells them). You may want to buy K&N's air filter top to get some more surface area to breath though.
Re: need advice: hood, manifold, carb & more (69stingray)
I think the hood on an '80 is the same as a '77, and I had no problem getting the RPM under my hood. I used a 1-1/4" drop base and a 3" filter :cheers:
The "ram air" effect of the cowl hoods is over-rated. The pressure rise due to this effect is negligible for speeds much below 100 mph. The cold air effect is not, however. Underhood temps easily exceed 150' during a normal summer day. A cowl hood or fresh air induction can drop temps 50+' which can definitely improve performance. I personnally like the looks of the L88 hood. You'd have plenty of room for just about anything short of a tunnel ram or 671 blower.
Glad to hear your buddy returned from his duty in Iraq without harm and that he saw fit to reward himself with a much deserved gift!! Congratulations to him and best of luck with his project!! :cheers: :hurray:
The Edlebrock performer intake and the Edlebrock performer RPM intake are definately two different intakes. The RPM intake is taller and will most likely not fit under a stock hood. The carb you showed is a direct replacement but you can get a Holly 4175 for about 1/2 the cost. If you check out Summit or Jegs you can find either the Holly or the Edlebrock cheaper than what you are currently looking at.
Re: need advice: hood, manifold, carb & more (LemansBlue68)
So if I understand correctly, the secret is to modifiy the air filter???, because I was looking at the rpm air gap as well, but am frouning at the idee in investing in a hood.
Cruise-In V Veteran
Re: need advice: hood, manifold, carb & more (Michel B)
here's a pic of my 80 with RPM intake, drop base and K&N Filter. I just put the hood on to make shure l didn't touch and it does fit. I Also have the New Edelbrock 650cfm thunder carb electric choke. If you can afford a New L88 hood that would be nice but it can fit under an stock 80 if you try.
:cheers:
[Modified by Riley, 11:50 AM 4/13/2004]
:cheers:
Re: need advice: hood, manifold, carb & more (Riley)
the rpm intake WILL fit under the hood with any standard drop base air cleaner. there is about half an inch of clearance though. so be absolutely sure not to leave anything on the air cleaner.
Re: need advice: hood, manifold, carb & more (neverendingproject)
Fit the RPM performer under my 81 stock hood.
Tight but fits with K&N drop base.
even Edelbrock said no go...but it does work
ok, all this talk of installing an L88 hood is something i have been interested in for the exact reason of engine compartment heat. with the rpm intake the engine flows better but you have to get you air from the engine compartment which is hot, is the air cleaner and ducting easy to get? if going to go through all the trouble would definatly like to know if the system was going to seal properly...
Re: need advice: hood, manifold, carb & more (rcastor426)
The 73-79 med. rise hood allows the Victor Jr, RPM & others w/ aftermarket dropbase & Holley. Cooler air can be taken in over the radiator or from the cowl. All that's really needed for a SB & allows BB. A good way to go for a SB as it gives a "stock" appearance to many.
The L-88 hi rise hood is only 7/8" higher than the 73-79 med. rise hood & allows a taller intake for BB.
Re: need advice: hood, manifold, carb & more (Ganey)
I have a 454 under the stock hood. Before you go to a cowl or L88 hood, sit in a car with one. I tried it out and really didn't like the lack of visibility. I'm about 5'10" and it interfered with the feel of the car because my eyes were always drawn into the black hole in front of me.
