Radio wiring?
Old 04-10-2004, 06:26 PM
micks69
micks69's Avatar
Default Radio wiring?
I am installing a custom sound radio and would like to know thw ID of the existing wiring on a 73 vette.
I have a connector with 1 yellow, 1 Black w/grey stripe, 1 grey. Which is the constant power? Which is the switched power and which if any are the ground? I'd check myself but I have no battery installed yet.
Old 04-10-2004, 06:45 PM
A C
A C's Avatar
Cruise-In II Veteran
Default Re: Radio wiring? (micks69)
I'd like to know this as well. The wiring diagram just shows the connector, and my last wiring harness was bubba'd, so I can't use it for a reference.
Old 04-10-2004, 07:13 PM
SlixVett
SlixVett's Avatar
Yellow is switched +12 Volts. Black is Ground. Grey is Dial Lite, +12V when the headlights are on.
Old 04-10-2004, 08:24 PM
micks69
micks69's Avatar
Default Re: Radio wiring? (SlixVett)
So there is no constant 12v in the harness? Can I jump a constant 12v from the lghter lead w/o problems such as blowing fuses when stereo and lighter are used together?
Old 04-10-2004, 08:39 PM
A C
A C's Avatar
Thanks, Todd. Mick, there is an open terminal on the fuse block with a male spade connector labeled "bat" which is constant 12V power if I remember right. I guess the radio light dimmer wire will have to go unused?
Old 04-10-2004, 08:58 PM
lostpatrolman
lostpatrolman's Avatar
Default Re: Radio wiring? (A C)
using the cig lighter constant should be fine.
Old 04-10-2004, 09:00 PM
micks69
micks69's Avatar
Default Re: Radio wiring? (lostpatrolman)
Thanks for the info! :auto:
To Radio wiring?
Quick Reply: Radio wiring?
