CORVETTE BRAKES
C6 the C5 of tomorrow
Re: CORVETTE BRAKES (CFL34)
Define 'best'
I have a brackets for using wilwood calipers on stock or 13" rotors.
Is it Better than the stock system? Depends on what you want...
It's not cheaper!
It's not cheaper!
hi cfl34,
I see that you are new! welcome!
I am using stock brakes accept for o-ring pistons and moderate performance pads.
But I added a hydroboost. That made a huge difference!! I can't imagine the brakes being much better. I had manual brakes before. converting to power is a big job and not cheap, but the C3 hydroboost kit was reasonable priced and it is a direct bolt on.
BTW- it is VERY hard to read all caps. If you turn off the cpas lock more people will read your posts.
~Jay
~Jay
Re: CORVETTE BRAKES (Mystery Machine)
There are VBP (Vette Brakes), SSBC (Stainless Steel Brakes Corp), and probably 30 other sources for various stages of iron Corvette calipers. At a minimum, they all offer at least a stainless steel bore sleeve to improve the raw, and rust prone iron bore. After that, you get into various options, like O-ring seals that address issues like air pumping and such.
You can also go to your local parts house and pick up rebuilt and new iron calipers.
There are alternatives beyond the iron caliper. Almost all of these alternatives reduce your unspring weight by using aluminum calipers. These alternatives do not significantly improve the factory brake performance unless your application is a lot of hard brake use such as running autocross events.
And, yes, "best" has no real meaning. You're not being charged by the word so the more specific you describe what exactly it is you're looking for the better the input you will receive. And please do turn off your caps lock.
Re: CORVETTE BRAKES (gerry72)
The BEST is the following;
Wilwood Superlite four piston calipers.
VBP's Aluminum hubs.
Coleman 13" rotors.
my brackets
It's also the best at lightening your wallet, about $1300 for the front.
Coleman 13" rotors.
my brackets
Re: CORVETTE BRAKES (427V8)
427V8
Can you please provide sources and part numbers for each of the components you mentioned? Also, can I purchase a set for front brackets from you?
Thanks, Will
Thanks, Will
