? about ignition/dimmer switch on column.
Cruise-In VII Veteran
St. Jude Donor '07
Bolting the column back in I noticed two screws for the switches that hold the dimmer and ignition switch on. One has a double sided bolt with a nut on the end. It is the back bolt/screw that holds the switches. What bolts to it?
Re: ? about ignition/dimmer switch on column. (Budman78)
The double is there so that you can place and adjust the ign. switch first and then adjust the dimmer switch.
St. Jude Donor '07
Re: ? about ignition/dimmer switch on column. (Jim Shea)
Thanks...
Now can someone with send me something to shrink my hands, so they will fit in there... :D
