81 Differential parts help
Need help finding a source for parts for the differential on my 81. The main gears are ok but the small shaft the holds the two small gears in the limited slip gears needs to be replaced plus there is four metal clips two on each side one side is broken and needs to be replaced. If someone has a diagram of the inner parts and a matching parts list it would help in ordering the parts needed. I was thinking that there may be a shop that can assist me in getting what I need?
:confused:
:confused:
Re: 81 Differential parts help (Bangkok Dean)
Also try IKERD's
DUB
DUB
