How to remove t-top cross bar??
How do I go about removing the t-top cross bar that goes from the back to front of the car, dividing the tops? I've taken out all of the rivets that I can find. I've removed all of the interior trim parts and still nothing. Can anybody give me a hand. I'm replacing the entire rear clip. But the new one I've got has a bad cross bar (front's rusted out a bit). Where as my old one on the car now is in great condition.
Thanks - James :beatdeadhorse: :banghead:
Re: How to remove t-top cross bar?? (Brutus2122)
If your talking about the steel piece it will have spot welds at the front (windshield frame) and back.
Steve :steering:
[Modified by stpman, 3:47 PM 4/6/2004]
Steve :steering:
Appreciate all the help guys. I'm sure I'll have several more questions before the entire project is complete. It's just the beginning.
ThanX :cheers:
ThanX :cheers:
Just cut it and weld the new piece to the old piece. This is the easiest solution. if you are a good enough welder you can grind the area down and you will never see the welds.
I'll try and take a pic of mine tonight.
Re: How to remove t-top cross bar?? (MikeC)
When I replaced the upper half of my WS frame, I cut the Ttop bar near the
back, and butt- welded the new piece onto it. Just take some good
measurements before cutting, so you get it back to the same size.
It's not how good a welder you are ... it's how good you grind the mess clean. :lol:
:seeya
:seeya
