Lectriclimited.com Breakerless conversion
Old 04-05-2004, 03:48 PM
AV8RSVT
AV8RSVT's Avatar
Default Lectriclimited.com Breakerless conversion
Is anybody running this conversion kit in there dist.? And how is it working out? Thinking about purchasing this over the mallory unilite conversion. I want to retain the ballast resister wire set up! :chevy Thoughts ideas opinions needed please.
Gary
Old 04-05-2004, 04:08 PM
Solid LT1
Solid LT1's Avatar
Default Re: Lectriclimited.com Breakerless conversion (AV8RSVT)
I use the Petronix Ignitor, it is a 2 wire system. I know the Lectric Limited system is only a 1 wire but, I have used Pertronix for better than 15 yrs without any failures. LL system is more expensive but, looks "stock" where Pertronix hooks up to both sides of the coil, STAY AWAY from optical systems like the Mallory!
Old 04-06-2004, 01:38 AM
AV8RSVT
AV8RSVT's Avatar
Default Re: Lectriclimited.com Breakerless conversion (Solid LT1)
ttt
Old 04-06-2004, 06:12 AM
Twin_Turbo
Twin_Turbo's Avatar
why?? because some people have problems with it? works fine here
Old 04-06-2004, 10:15 AM
AV8RSVT
AV8RSVT's Avatar
Default Re: Lectriclimited.com Breakerless conversion (Twin_Turbo)
Hey Marck
Thank you for replying! How are you doing!! Are you running the Mallory unilite? :D
Gary
Old 04-06-2004, 10:29 AM
ettev
Support Corvetteforum!
ettev's Avatar
Installed the Breakerless SE kit in my 1970 SB. Actually installed it in the original distributor. Car works fine. Single wire makes it nice, too. I had my distributor out of the car to install the kit. Not required, but probably makes it much easier.
Old 04-06-2004, 05:13 PM
BB68Vett
BB68Vett's Avatar
I can't speak to the LL set-up but it looks nice. I have run Mallory Unilite for 5 plus years with no problems. If price is an issue and the LL set up is more money than you want to spend, I wouldn't hesitate to buy the Mallory Unilite.
Old 04-06-2004, 05:46 PM
BlueL36
BlueL36's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
I converted to this system last July and ran it until I put her in storage in November. Started her again after I did some work under the hood. Runs great. You cannot tell you have this under the cap.
Old 04-06-2004, 08:55 PM
69driver
69driver's Avatar
Default Re: Lectriclimited.com Breakerless conversion (BlueL36)
I had a Mallory Unilite set in my distributor. It had failed on me. I ended up going with MSD and getting a new distributor with the tach drive. Works like a champ!
Old 04-06-2004, 09:02 PM
Jvette73
Jvette73's Avatar
Still running the PertronixII here with no problems. Been a couple of years now.
To Lectriclimited.com Breakerless conversion
Quick Reply: Lectriclimited.com Breakerless conversion
