79 Headlight Vacuum info needed
On a 79 where was the vacuum connected to the intake or the carb.? Was there a filter/check valve mounted in line? On a 79 is the front crossmember used as the vacuum tank? If anyone has or would be willing to shoot a couple of pictures they would be greatly appreciated.
Thanks,
Bob
Thanks,
Bob
Re: 79 Headlight Vacuum info needed (87bob)
I've got a 7 page or so write up with diagrams. Give me a couple of days and I could get it scanned in I have no idea where I got it from.
[Modified by gkull, 9:53 AM 4/6/2004]
The vacuum tank is the cylinder runnining across the frame at the front. The vacuum source is fitting behind the carb. on the manifold. Three vacuum hose. There should be a check valve and filter, one line going into thew filter I think and two coming out.
Re: 79 Headlight Vacuum info needed (pik)
Thanks for the reply! It backs up what I have been able to find out so far. Now I need to find out the G.M. part numbers for the filters and check valves.
