Intake questions
Intake questions
I was just on the Edelbrock site.
What kind of gains could I expect from the Performer EPS?
Are their cams any good?
Also, the Performer Air Gap says it doesn't fit under a stock Corvette hood.
Even if you use a drop base air cleaner???? :confused:
Anyone have experience with Holley intakes?
How do they compare to the Edelbrocks?
Re: Intake questions (79-L-82)
i have the performer rpm( non air gap) , eps 800 carb & a drop base air cleaner on my 80. i have less than 3/4" clearance. id say no way on the air gap w/ the stock hood.
Re: Intake questions (neverendingproject)
I just put my rpm on Sat. on my 79 and putting on a 750 edelbrock with the triangle low profile Edelbrock air cleaner..I'm sweating the clearance. :leaving: :rolleyes: not going to be much...
The Holley 300-36 is very good & may put more power under the curve than the RPM w/ L-82 cam.
The RPM fits under the 73-79 med. rise hood w/ Holley & drop base filter.
I have A "72" small block with A stock intake, does anyone know how tall this intake manifold is?? or where I can find out?? THANK YOU!!!
Gary :steering:
Gary :steering:
