Door locks
Door locks
79 with power door locks. Turned the key to open and the key slot turned parallel to the ground and refuses to move. The door is unlocked but will not lock.
Re: Door locks (chewy)
Did the whole lock turn in the door? I've seen this several times where the fiberglass gives way and the lock turns. If the just the cylinder turned it sounds like something is jammed on the latch. Craig
