Dynomax Cerama-Coat Headers for my 75, your thoughts?
I'm thinking of going with Dynomax Cerama-Coat Headers for my 75. These will replace some older headers currently on it. Does anyone have any experience with these headers? I'm really looking to find out how well they will fit and if I will have any issues. BTW, the car has A/C.
Re: Dynomax Cerama-Coat Headers for my 75, your thoughts? (Scudd)
They will be OK however they probably won't bolt right up to your existing exhaust for some reason the Dynomax collector seems to point toward the ground a little on an angle not much but enought to screw up the geometry. :D
I like 'em. Good choice for the money. I did fab up some spacers for my current AC bracket (had to be about 1" and 1 1/2" long, so I turned them out of aluminum bar stock on a lathe. There are AC brackets available, and since you already have headers, I would guess the same brackets you currently run will work fine.
