HEDMAN's Exhaust Equalizer Kit
Has anyone installed the Hedmans exhaust equalizer kit? Some good info on the crossover pipes on their website for those of us who need it. I'm going to install dual exhaust and was reading up on X vs H crossovers.
"HEDMAN's Exhaust Equalizer Kit completely eliminates firing order pressure differences between the right and left banks of the exhaust manifolds, or hedders. The tangentially siamesed crossover junction synchronizes the exhaust pulses.
The firing order of all production V8’s, regardless of make, has one cylinder in each bank that will fire within 90 degrees of crankshaft rotation of another cylinder in the same bank. This occurs twice during completion of the entire firing order. These two cylinders will be exhausting almost simultaneously into the same manifold system. Full length 4 tube hedders help separate these pulses until the collector is reached. After the hedder tubes dump into the collectors, the two cylinders again are fighting each other for space in the collector and exhaust pipe. The result is reflected pressure waves traveling back up the exhaust system, backpressure, lost power and poor economy.
At the same time two cylinders exhaust in one bank, there is no activity in the opposite bank. The traditional H-Pipe equalizer allows some of the excess pressure to bleed over the “quiet side” of the exhaust system, resulting in some low and mid-range torque improvements. At high RPM’s however, the gases cannot bleed across the H-Pipe fast enough to help power significantly. Hedman’s X-TREME equalizer pipe splits the flow in the crossover junction so the pressures on both banks will be equal and pulse free after the crossover, regardless of the RPM. Volumetric efficiency and power are therefore improved at all engine speeds.
Re: HEDMAN's Exhaust Equalizer Kit (USA SHARK)
I've read the same thing and it sounds good. I plan to install the equalizer in May when I can get the new engine and other accumulated parts installed.
Re: HEDMAN's Exhaust Equalizer Kit (Never Finished)
I've seen this for quite a while and just question if a MILD small block already sporting hooker headers and 2.5" exhaust really pushes out enough volume of gas to require the x-pipe? Maybe a BB and I could be wrong.
I just don't want to have the Ricer mentality. You know 60HP 4 cylinder with a 3" exhaust going to a 5" chrome exhaust tip. OVER KILL
:D
[Modified by Cali,68,L-79, 1:12 PM 4/3/2004]
:D
Re: HEDMAN's Exhaust Equalizer Kit (Cali,68,L-79)
Cali, you bring up a good point. Is it really necessary on a small block or can you just run straight duals? In addition to adding performance, I thought it also evened out the sound. I may be wrong too. Anyone have any info on SB vs BB with X pipe?
If you're reffering to the Hedman X-pipe kit, I have it installed on my '77 along with Hedman headers, 2.5" duals, and Flowmaster 40's. I got the "X junction only", not the one with the pipes already attached to the X. I'm happy with my exhaust system, I like the sound, and it has very little resonance :cheers:
Re: HEDMAN's Exhaust Equalizer Kit (73 Vet)
The only place with room for an X is behind the cross-member. In front of the cross-member, the transmission hangs down too low to allow a junction.
It definitely improves the sound at high RPM. Even and smooth.
[Modified by L79vette, 10:39 AM 4/4/2004]
