Bolt pattern, backspace, offset
Could someone tell me what other vehicles share the same bolt pattern, backspace and offset as my stock slotted alloys?
(5x4.75, 4" backspace, 0mm offset)
The reason I ask, is because I plan on buying a set of fancy aftermarket rims/tires for show and would like to get an idea how easy it will be for me to re-sell once I get tired of them.
Thanks!
Thanks!
CFOT Attention Whore
Re: Bolt pattern, backspace, offset (82Red)
in reality, not many. but don't sweat it. the reason is not many cars had tires as wide as the corvette. i've seen the factory aluminum wheels on everything from a '70s grand prix to an el camino. most every G.M. vehicle made up to the early '80s used a very similar wheel design. if you want to sell them later, advertise to the f-body, el camino, chevelle crowd. that's your best bet.
