Radiator fluid leak, behind the right front tire??????
Old 04-02-2004, 12:32 PM
Shoehorn
Shoehorn's Avatar
Default Radiator fluid leak, behind the right front tire??????
I have notice a small wet spot on the ground, right behind the passenger side front tire now twice. It has the color, smell and consistancy of anti-freeze. Where would this be coming from?
Old 04-02-2004, 12:40 PM
71vert
71vert's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (Shoehorn)
Check your hose from your overflow tank, thats were it is usually routed.
Old 04-02-2004, 12:47 PM
Harv69
Harv69's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (71vert)
If its not the hose to overflow tank then its the heater core. My 81 is presently leaking and it leaks behind the front right wheel , and on the interior of the firewall (on carpet).
Old 04-02-2004, 12:48 PM
JB
JB's Avatar
St. Jude Contributor
Yep, probably overflow.
JB
[Modified by JB, 11:48 AM 4/2/2004]
Old 04-02-2004, 12:49 PM
Avette4me
Avette4me's Avatar
Cruise-In VIII Veteran
On my '80, both of the heater hose lines kind of run in that area. They connect at the bottom side of the heater box...ya might check there....
Old 04-02-2004, 01:04 PM
theandies
theandies's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (JB)
JB
:iagree:
Old 04-02-2004, 02:09 PM
Shoehorn
Shoehorn's Avatar
I'll check that, thank you. :cheers:
Old 04-02-2004, 02:10 PM
68shark
68shark's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (theandies)
JB
:iagree:
:iagree:
Especially if your car is running hotter than normal for any reason. Way to correct is figure out why it's running hot. Inadequate cooling system, running too lean, timing misadjusted, rad cap not holding pressure. The list goes on and on.....
Old 04-02-2004, 03:05 PM
Brown78
Brown78's Avatar
:iagree: All of the above!!!
Old 04-02-2004, 03:21 PM
flood
flood's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (Brown78)
could be the lower rad hose , but that would be leaking inward from the passenger tire. :cheers:
Old 04-02-2004, 04:29 PM
A2Shark
A2Shark's Avatar
Could be a lot of things when it is leaking from that area. Lets see... In the past couple years I have seen that leak due to a bad lower radiator hose, a bad heater hoses, and a failed seal on my water pump.
Warm up your engine and try to find out where it is dripping from. Otherwise, you will just be chasing your tail.
Old 04-02-2004, 06:03 PM
robertmc48
Support Corvetteforum!
robertmc48's Avatar
When I bought my 1973 and the first time I turned on my heater it leaked from there too. It was the heater core.
Old 04-02-2004, 07:50 PM
12stepvette
12stepvette's Avatar
St. Jude Donor '03-'04-'05-'06-'07
I`ve also seen the overflow tank fail...usually at the molded in mounting tabs or a seam
Old 04-02-2004, 09:36 PM
Aflac
Aflac's Avatar
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
If you have a ball type vale shoutoff for your heater, check there.. I just fixed mine today...
Old 04-02-2004, 10:38 PM
kenko74
kenko74's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (12stepvette)
:iagree: My tank lasted 30 years, then it started ever so slightly leaking at the lower tab seam.
Replacements are easy to get at any Corvette parts supplier.
Old 04-07-2004, 04:54 PM
Shoehorn
Shoehorn's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (kenko74)
Well, I found that it's my Expansion/recovery/overflow tank but I have only found 74-77 and 77 L-82 replacements online. Any one know where I can get one for my 1980 L-82?
Edit: I found one, thanks.
[Modified by Shoehorn, 4:13 PM 4/7/2004]
Old 04-07-2004, 06:43 PM
72GACRZR
72GACRZR's Avatar
MA Direct has some, see this link
http://www.madvet.com/shop?frame=1.138.1227
Old 04-08-2004, 01:47 PM
Shoehorn
Shoehorn's Avatar
Default Re: Radiator fluid leak, behind the right front tire?????? (72GACRZR)
72GACRZR,
I went to the web site URL that you gave me and I didn't see any for my 1980. I have one on order through GM parts here in town for about $20 which is about the same as a mail order place including S&H. Thanks for the information though. :thumbs:
To Radiator fluid leak, behind the right front tire??????
Quick Reply: Radiator fluid leak, behind the right front tire??????
