Turn signal lever w/Cruise, trying to find
Old 04-01-2004, 10:17 PM
Skyhigh82
Skyhigh82's Avatar
Default Turn signal lever w/Cruise, trying to find
Can't find one for an 82. OEM has three-wire connector. Got an 84-89 lever form Ecklers but it only has two wire connector. If I do a search on vendor’s catalogs I only get a turn signal lever w/o Cruise.
Old 04-02-2004, 02:41 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Default Re: Turn signal lever w/Cruise, trying to find (Skyhigh82)
So far I can't find ine either...
Corvette 1981-1982 Turn Signal Lever w/ Cruise -SORRY-DISCONTINUED
Old 04-02-2004, 02:50 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Dr. Rebuild show it in his catalog.
http://docrebuild.com/dr-r-web/COURT.PDF
Or search for part Number #563003 on
http://www.corvettecentral.com/
Hope this helps......... :seeya
Old 04-04-2004, 06:56 AM
Doc Rebuild
Doc Rebuild's Avatar
Default Re: Turn signal lever w/Cruise, trying to find (Desertdawg)
Gentlemen:
I regret to inform you that GM has indeed discontinued that particular part. Please DO NOT think that this part is available if it is listed in any catalog. Most catalogs are months behind in factual data regarding availability. By the time 200+ pages are codified some price data has changed. Regretfully there is no OLE that functions across different media to allow automatic updates everywhere.
Also please note that the pdf file referenced is from a 1999 publishing date. I personally only know of 2 of these NOS levers and one may be spoken for. I always keep the last NOS sample should I ever need one.
I certainly would prefer that GM never discontinue a Corvette part because they just about always look, fit and function flawlessly. And generally the supply is steady, for a while. However, those decisions on the obsolescence are not under my control or purview.
When an outside vendor produces the part, GM issues them a form authorizing the vendor to sell the tooling for the scrap metal value and reimburse GM for some of that value if GM does indeed own that tooling. At one time over a decade ago, I had a friend at GM who would send me copies of those forms. In a few instances some folk have even purchased those tools that were sold for scrap metal. Today all the remaining obsolete tools are looked at as a source of licensing revenue by the external marketing agent that vends the GM restoration part licenses.
Geoffrey Coenen
NCRS #2473
NCM Lifetime #105
Precision Valley Corvette Museum Charter Member #20 (I think)
Retired #1 56, 63, 67, 68, 68, 69, 75, 99 and I want more! :D
I am still looking for a nice loaded 1969 L-89 conv (no project)
Old 05-07-2011, 07:10 PM
jrc3vette
jrc3vette's Avatar
I have the same issue. My 82 that I bought 2 months ago has all the cruise components under the hood, but a turn signal lever without cruise buttons on it. I cannot find a lever with cruise controls anywhere. Anyone have any ideas? Is there someone that brokers used parts? Thank you in advance for any suggestions!
Old 05-07-2011, 07:56 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
You might try Rik's Corvette Parts (1-888-RIKS-VET). Their catalog lists part #STE184 for '81-82 Turn Signal Lever w/Cruise.
Old 06-24-2011, 10:01 PM
jrc3vette
jrc3vette's Avatar
I found a GM part number that looks like it might be able to be adapted to work. It is 25074397. Has any one tried this P/N on an 82?
Old 06-24-2011, 10:14 PM
kevakasper
kevakasper's Avatar
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
There is one on E Bay....for $350.00
I just fixed mine!
Old 04-06-2012, 07:11 AM
scott_vette22
scott_vette22's Avatar
There's one on eBay over here in the uk. I think it's cheaper then $350.
Old 04-06-2012, 08:35 AM
bmans vette
Support Corvetteforum!
bmans vette's Avatar
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Try corvettemack on ebay in Atlanta.
The guy has used parts for everything.
Good luck
Bman
Old 04-06-2012, 12:21 PM
7T1vette
7T1vette's Avatar
What is wrong with that lever? Is the lever body actually broken? Or is it just a bad switch?
I'm not familiar with that particular lever but, unless the switch is actually molded into the lever body {which would be unusual}, some careful disassembly should yield the switch detail. And, normally, GM would not make a special switch detail for a specific model/year; they would use a 'common' switch design and install it in a 'specific' lever. If that's the case, you could probably get a junked switch lever from any '81 GM full or mid-sized car and remove the switch from that one and stick it in your lever. Just a possible alternative to repair yours, if the lever body is still intact.
Good luck with it.
Old 04-06-2012, 12:25 PM
kevakasper
kevakasper's Avatar
Mine was really loose at the mounting boss on the column. I couldn't find one eiter. I just pulled the knurled shaft out of the boss, mixed up some JB Weld and reinserted the shaft. Let 'er dry overnight and solid as a rock now. You can actually use it as a turn signal lever now!
To Turn signal lever w/Cruise, trying to find
Quick Reply: Turn signal lever w/Cruise, trying to find
