Secrets to disassembly of a double pulley alternator?
Anyone have any way of getting to the nut on a double pulley alternator? I can't get a wrench in there, it's to deep.
Thanks in advance.
Thanks in advance.
Received 4,927 Likes
Re: Secrets to disassembly of a double pulley alternator? (thevetterisbetter)
Socket and 1/2" drive impact gun.
Hold the pulley fan with gloves on and USE AN IMPACT GUN
Steve :steering:
[Modified by stpman, 11:18 AM 4/1/2004]
Steve :steering:
Re: Secrets to disassembly of a double pulley alternator? (427basketcase)
.. or a strap wrench to hold the pulley while using ratchet.
With an impact wrench, you won't need to hold it much. It should spin right off.
:seeya
:seeya
Re: Secrets to disassembly of a double pulley alternator? (NHvette)
Impact guns put the force on the center instead of out at the end of the breaker bar or ratchet.Things that seem impossible come apart easy with an impact gun.. Ingorsal Rand is one of the more powerfull ones. Even the fea market specials are better than bt hand when dealing with things that spin. Wait until you try to remove the fly wheel from an old VW beatle. ONE 25MM nut. The engine tries to turn ove even with the entire neighborhood trying to hold it. NOT fun.
[Modified by bluevetteman, 1:38 PM 4/1/2004]
How do you keep it from spinning though if you just use a socket?
