When you know you shoulda changed the bearings 100 miles ago...
St. Jude Donor '07
Awhile back my rear wheel was making a lot of noise. At first I thought it was just parking brake hardware, but when it turned out not to be, I figured it was the bearings and I probably had a few hundred more miles. Not so; as I was driving to my cousin's house, it started snapping and grinding, not very good noises. I pulled the bearing housings off and sent them in to Corvette Mike for new bearings, and this is what they pulled out:
This is from the right rear, most of the rollers are missing, the cage is broken and it looked bone dry. I think from now on I'll grease or replace them every 100k miles or so just to keep them from seizing up on the spindle.
Re: When you know you shoulda changed the bearings 100 miles ago... (Steve's74)
are those pics from both right hand bearings or are they one and the same??
Those rollers that came otu relly did their job...wow. What about the spindle and the hub? they probably are toast too ?
Re: When you know you shoulda changed the bearings 100 miles ago... (Buffalo Dude)
:eek: Good thing you were able to get it fixed. I'm new to Corvettes - sold my 66 Mustang that I had for 16 years to buy the Vette I'm fixing up now - but I had a front wheel bearing seize up on me in the Stang. It was tightened too much, grease dried up, bearing got hot and welded itself to the spindle! On the highway too. Pain to fix but it got done.
St. Jude Donor '07
Re: When you know you shoulda changed the bearings 100 miles ago... (78 Vette)
:crazy: :crazy: :crazy: holy cow it must have sounded horrible
St. Jude Donor '07
Re: When you know you shoulda changed the bearings 100 miles ago... (VettePower)
Every 100 thousand miles???? How many miles a year do you drive it! :eek:
