68 steering column
68 steering column
Could someone go through the steps to lower the steering column on a 68. I need to remove my tach and speedo and don't want to screw anything up.
THANKS
THANKS
Re: 68 steering column (Corey 68)
You may also want to loosen the two bolts near the floorboard. No need to take them out--just loose. You don't want the entire weight of that column prying on your floor and possibly cracking it. I don't remember if you have to take it loose from the steering box coupler as well. It's been a while since I dropped my column. I took it all the way out.
