Check em out!
Check em out!
Still have to figure out rerouting the spark plug wires and looms. Then I have to come up with something for the dipstick. I just hope the headers are the right ones as it might be a while before I actually get them installed.
Re: Check em out! (verskel)
They look a lot like DynoMax! :)
Re: Check em out! (C3w4sp)
I am using these:
http://store.summitracing.com/partde...57#largerimage
and this:
Just make sure you check it when the eng is cold. :)
and this:
Re: Check em out! (Fevre)
Fevre
The R & M's are my first choice. I have centerbolt valve covers and they make some looms just for them. I 'm using 8.5mm MSD superconductors and I don't know if the holes in the R & M's are big enough, what do you think?
I went with these on my Formula with center bolt covers:
http://store.summitracing.com/partde...5035611&view=1
It says for 7-8 mm wires but I have 8mm Accel wires and they will slide in the looms if you pull on them so I bet you could squeeze 8.8mm in em. I was going to go with the R&Ms but wanted something a little diff than my vette.
Fevre, how tight are the R & M's on your wires?
