Head light switch
Location: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Head light switch
anybody replace the headlight switch in a 79? Where is it located and how much trouble to swap?
St. Jude Donor '05-'06
Re: Head light switch (verskel)
Its behind the switch.
I had mine out last week. You need to at least lift the dash, if not remove it.
1. Remove windscreen header.
2. Remove pillar post pads
3. Unscrew dash and lft up - carefully
4. Push headlight switch button release (spring loaded button on switch) and pull the headlight switch **** and shaft stright out towards you.
5. Unscrew nut holding on the switch to the dash (on the outside)
6. Push switch back, disconneect vacumm lines and electrical plug. Tie vaccumm lines where you can get to them.
Reverse for installation.
Longest time will be the dash and pads, rest is easy.
[Modified by stingry, 3:19 PM 3/30/2004]
Re: Head light switch (feb18blacksunday)
check this out:http://forums.corvetteforum.com/zerothread?id=598375
one of my successful repairs. they don't all go this smooth. :rolleyes:
Re: Head light switch (isosceles)
My headlights work fine I am just blowing my tail light and instrument lights. Is there a regulator that powers the taillights?
