Question on big block valve covers
Finished putting the engine together yesterday, just need to add valve covers. I have the originals but they're kinda beat up. A few dents, lots of rust pits, etc. What is everyone running for a big block with power brakes? Don't want to order something now & then have a problem when the body goes back on.
Thanks
Jim
Thanks
Jim
St. Jude Contributor
Re: Question on big block valve covers (70BBvert)
I use some inexpensive ones (about $30) I bought off ebay. There are a lot of them listed there. I got the ones with the relief "dent" on the driver's side for the brake booster, but there's plenty of space in there, really, and I don't think you need the relief, so pretty much any normal (as opposed to the aftermarket tall ones that are made to clear roller rockers) covers ought to work.
JB
JB
Re: Question on big block valve covers (GDaina)
I bought a pair of these but I haven't put them on yet....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2469041255
no drippers, tho.. but you can't beat the price. :) MJ
Re: Question on big block valve covers (MNJack)
One other consideration--the originals are only flash chromed, which is very thin and not quite as shiny as the triple chome on the repros. That's both good and bad, because the repros are less prone to rust spots and definitely look better, but it's also pretty easy to anyone who knows what the originals look like to tell the difference, if that's important to you.
JB
[Modified by JB, 4:29 PM 3/29/2004]
Re: Question on big block valve covers (JB)
The covers I have are not dented to clear the booster. Probably not originals though. I did a search earlier & came across some comments that dented covers are not needed for 69 & up. Cranes corvettes says there are 4 types, with 70 - 74 needing a cover with a sloped end. Hmmmm maybe I'll just clean these up & install them for now. Then I can research further & buy a good set of chrome when the car is complete.
Thanks for the help
Jim
Thanks for the help
Jim
Thanks for the heads up Mark :cheers:
Jim
I confess :D bought those last night. For the price, $18.50 its not worth cleaning the old ones. Besides it'll look better on the stand :lolg: .
Jim
Jim
Jim,
My original BB valve covers did not have the large brake booster indentation, only a small relief in the back of the drivers side valve cover.
If you ever want to go back to stock covers here is how I refinished mine.
http://forums.corvetteforum.com/zerothread?id=776364
Re: Question on big block valve covers (GATOR454)
Jim,
Jim
That's why I'm going to eventually get my originals rechromed--that only costs about $70 a cover. There were four different styles in 1969 & the cheapo repros only come in slanted or not slanted, so to look right, that's the way to go unless you can luck into the exactly correct OEM covers on ebay. What I can't decide is whether to get my originals rechromed with the correct but cheap, thin, and easily damaged flash chrome, or to go unoriginal and have them triple chromed.
JB
JB
[Modified by JB, 4:35 PM 3/30/2004]
JB
JB
If you pay up to have the originals triple chromed.... they will look just like the $18 covers! :lol: There are so many variations on the originals I can't figure out what mine are supposed to look like anyway. MJ
