Key Buzzer re-installation?
Does anyone have a larger diagram showing how this metal clip is installed? It hold the key buzzer in. I cannot figure out how it goes back in.
[Modified by Skyhigh82, 5:31 PM 3/28/2004]
[Modified by Skyhigh82, 5:33 PM 3/28/2004]
Re: Key Buzzer re-installation? (Skyhigh82)
Go to http://www.corvettefaq.com and click on the diy section dealing with steering columns that Jim Shea wrote. Find your particular application and download the exploded parts breakdown. Jim is a retired engineer from Saginaw and knows more about steering columns than any one of us ever will.
You will need a new buzzer. I believe that this piece is the copper contact that fits inside a plastic case that fits down into a slot in the steering column. Once you have removed one you can do it in your sleep. Quite simple really. IIRC, GM still sells that particular switch.
Gary
Gary
