Steeroids
Steeroids
Adjusted the binding out of my steeriods. Had to take the more in-depth step of loosening the 2 firewall nuts from under the dash and pushing the column toward the engine in the engine bay.
I was able to get the knuckle away from the header.
It worked. The steering is still slightly stiff, so I don't think it's exactly perfect.
C6 the C5 of tomorrow
Re: Steeroids (page62)
The problem is also the clutch linkage, in an auto car it's much easier...
Also my header design makes it easier too.
I sure am glad I didn't have to work around a clutch!
Re: Steeroids (427V8)
If you guys want to see "close" I can post pictures. I've got my header dimpled to the point where the joint is about 1/8" away from the header.
