Radio Install problem!!!! NEED HELP!!!
I recently bought the custom autosound radio..and I am having a few problems.. It works fine..but I cannot figure out where to connect the memory(orange) wire too. It is a 1980.. If anyone has any ideas..PLease elt me know..as I hate tuning and everything all the time! Thank You!! :withstupid:
Re: Radio Install problem!!!! NEED HELP!!! (Jack71)
So splice a new wire from the fuse box around and under to the dash to radio... Couldn't I also put it on the courtesy/radio fuse?
Re: Radio Install problem!!!! NEED HELP!!! (Stoge)
I spliced into the cigarette lighter. It has caused no problems whatsoever.
Ron
Re: Radio Install problem!!!! NEED HELP!!! (Ron 75 L48)
There may be a post on the fuse panel that is labeled batt. This should be live all the time. The lighter will work also
