79 window trim
79 window trim
I've got chrome window trim and I want black. I can powdercoat it but I don,t know how to remove it or put it back. I did it on an old truck once and it was tough to get back on correctly. Is tere an easy way?
Re: 79 window trim (bodaman69)
i have black trim on my 82. i cleaned the trim then taped all around it .i used the trim paint and it tuned out fine . have been told to be verry carefull removing rear trim around window .the window tabs that hold the trim on can break ,then you have to have the window taken out to fix the tabs.
