Steering column experts needed
In the first pic there is a hole in the bottom of the casing. Is this normal or do I need to replace it? The tilt lever housing covers it and it doesn’t look like anything’s supported by it but there is a metal rod that extends through it.
The second pic is a spring that fell out when I removed the cover, any idea where it goes? I’ve looked at all the diagrams but not really sure what it is.
Thanks
Thanks
Re: Steering column experts needed (Skyhigh82)
The hole is normal. The spring goes on the white plastic key warning switch. The one with the two brass conectors coming out of it.
