Hooking up aftermarket alarm
I was wondering which do i use for the door trigger(+ or -) and where do i connect. Also wont it be a bit of a problem tying into the door switches because in order for them to work you need to lock the driver door(the method for the factory alarm)
andy help is appreciated
thanks, sonny
thanks, sonny
Re: Hooking up aftermarket alarm (battsup)
Sonny,
I tied into the existing door alarm switches that ground when the door is open. I can't speak to your system but on mine the door lock arming switches do not affect this trigger. :yesnod:
Dane
Dane
ok so hook up the negative door wire to blue wires from the door locks?
