78 Tilt/Telescope?'ssssss
Cruise-In VII Veteran
St. Jude Donor '07
1) It looks like the plate that locks the column is bent. It locks on one half of the turn and not on the other. I guess I could remove it again and put it on a flat surface.
2) I noticed on the detail that there is two plastic bushings and a piece of rubber hose after the cancelling cam retainer. The it shows a clip and the spring for the horn assembly. I missing that clip, what does it look like? Where can I buy it.
3) What makes the column telescope lock. I turn the lever and it still moves in and out.
Thanks :cheers:
Thanks :cheers:
St. Jude Donor '07
Re: 78 Tilt/Telescope?'ssssss (Budman78)
Problem 1) I think I resolved. The C clip that retains the locking plate is two sided. One side it flat and other side has a relief on half of it. The reliefed part of the clip is pushing the lock plate out on one side. At least I hope that is the problem.
The only place that I have found that sells the large C-clip is Dr. Rebuild. Go to his websight and look at the blowup drawing on page 158. The part is labeled "F" 69-82 Upper Steering Shaft Lock Plate Mtg Clip "U" Shaped 6521124 $7.60 Make note that his websight says that pricing may not be uptodate.
His blowup drawing is quite good with respect to the parts in a T&T column.
On the lower blowup drawing shown on page 156.
Your telescope locking ring is attached to a "star" screw "E".
Now go back to page 158.
The "star" screw pushes on "RR" 78-82 Upper Shaft Lock Rod 6521532 $10.20. The lock rod ***** a locking wedge "TT" 69-82 Shaft Locking Wedge 6521176 $11.95.
You need all of these parts to make your shaft lock.
St. Jude Donor '07
Re: 78 Tilt/Telescope?'ssssss (Jim Shea)
Jim,
Looks like I misplaced that internal rod. I also think that clip that GM shows on their detail is the upper bearing retaining clip.
Thanks,
Buddy :thumbs:
Thanks,
Buddy :thumbs:
