When your 78 Tilt/Telescope is full extended can you see into the column?
Cruise-In VII Veteran
St. Jude Donor '07
Trying to set up my steering column and there is an air gap fully extended. About 1/8". Is this normal?
Re: When your 78 Tilt/Telescope is full extended can you see into the column? (Budman78)
don't know why but i checked on about 6 columns and they all had that gap. gary dale
St. Jude Donor '07
Re: When your 78 Tilt/Telescope is full extended can you see into the column? (Gary Dale)
Weird. Maybe Jim Shea can step in on this one.
Before I rebuilt mine it never did, haven't put it back together yet to tell you the recent outcome, but I'll be looking now.
Re: When your 78 Tilt/Telescope is full extended can you see into the column? (john V. zemba)
sorry i dont mean to hijack the thread but how do you telescope? i know how i can tilt but i dont know how to telescope.
Re: When your 78 Tilt/Telescope is full extended can you see into the column? (battsup)
With you fingers, twist the metal piece between the horn button and the steering wheel. Turn it counterclockwise to loosen, move steering wheel in or out to desired depth, then turn it clockwise to tighten so steering wheels stays put.
Mike
Mike
