COMP Extreme Energy or Magnum?
It appears the Extreme Energy line from COMP is the most popular but what about the Magnum line? Is it old technology? Are they still good cams? How do the two lines compare to each other besides the obvious single pattern vs dual pattern?
Re: COMP Extreme Energy or Magnum? (nastee383)
I have had two Magnum cams and I like them alot bit for my new 406 I am going to try an Extreme Energy solid roller because the duration is going to be right up there and they say this line makes more vaccum. :D
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: COMP Extreme Energy or Magnum? (MotorHead)
The Magnum's are bit much for daily / street driving. Go with the Extreme Energy series. They usually have a split lift/duration style that gives a little more help to the exhaust side.
The Comp Magnums I recall are mostly single pattern cams and single patterns work better/more effective on low compression motors . Single pattern cams are more effective at lower duration (<270*) too but Magnums are mostly higher duration cams. :lol:
I'd say the edge for a cam with duration longer than 270* would go to the Extreme Energy. Exspecialy with stock like heads that need the greater exhaust duration for cyl blow down. :rolleyes:
Re: COMP Extreme Energy or Magnum? (cardo0)
For what it's worth I just got one of the solid XE's for my smallblock- the Comp Cams tech simply stated that it's a newer design & I'd like it better. :cheers:
[Modified by Les, 1:33 AM 3/26/2004]
[Modified by SpyderD, 1:43 PM 3/26/2004]
My understanding of the XE series is that they have steeper flanks than the old Magnum grinds in an effort to bridge the gap between the old hydraulics and the new roller cam designs. I flattened my first XE-274 in 2000 miles,a feat I'd never done before,so I guess the ramps are more agressive. I now run the XE-284 with 1.60 rockers and love it,though I toy with the idea of a solid lifter grind next go around.
In answer to the question,definately use current grinds. They're light years ahead of the old technology. :yesnod:
Re: COMP Extreme Energy or Magnum? (The Money Pit)
My question is why even use a CC?
Well let me get a bit more specific. Feel free to dissect this combo and tell me what you feel is right or wrong with it.
383SBC, 10:1 compression, Canfield 200's ported and bowl blended, COMP Magnum 286 hydraulic roller (230@.050 .598 lift w/1.6 rockers), Performer RPM Air Gap, Childs and Albert ZGS gapless moly rings.
I hope its not too screwed up because it's already being built! :eek:
BTW Vizard, Yunick, Lingenfelter promote dual pattern cams for high compressions and only Vizard promotes single pattern cams for low compression engines. Single pattern cams are(were ?) cheaper to manufacture. :conehead
