Eletrical Gurus
Eletrical Gurus
What the secret for releasing the terminal inside a connector. Its a slide on type for the wiper switch. Terminal is loose need to fix it. Thanks :confused:
Re: Eletrical Gurus (7782vette)
I think you slide one of those tiny flat blade screw drivers in there to compress a little tab??? look at it good first if wrong it could brake :skep:
A CI-6 Car Show Winner
:iagree: The little tiny locking tab is on the "closed" side of the connector. You need something really small to release it like a pick or tiny jeweler's screwdriver. Insert the pick from the wire side and be gentle, the connector will push out the opposite way.
:thumbs: :party: cool i just remembered :lolg: A ice pick works .. if you don't stab yourself :lolg: :lolg: :lolg: i have good blood, clots quick :lolg:
St. Jude Donor '09
Re: Eletrical Gurus (comp)
:lolg: :lolg: :lolg: i have good blood,.... clots quick :lolg:
