12v start/run
12v start/run
Hi, guys , I am new to the forum but I am not new to vettes and engines etc. I have a question . I recently installed a Tilton starter (mini) and converted my points to HEI . Could anyone tell me where to find a switched 12v. for start and run . thanks, Brent
Cruise-In IX Veteran
Re: 12v start/run (Brent Brooking)
The fuse panel would be the first choice. You should also have a ballest resistor that supplied 12v switched to the coil for the points that you should be able to use. That should be located on the firewall by the windshield wiper motor on the drivers side.
