can i weld this
Old 03-25-2004, 12:24 PM
cryzko
cryzko's Avatar
Default can i weld this
well people,
i finally got my trailing arm assemblies dismantled and started sandblasting them so i can have some of the parts chromed or powdercoated. my question is that i have some indents in the half axles and i wanted to know if i can fillet weld them and grind it down so i can get them smooth to be able to get dipped? also, what are all the main parts made of in the assembly i.e. cast iron/steel....... will there be a problem with chroming if it is cast iron?
thanks
cryzko
Old 03-25-2004, 12:34 PM
LOTAHP
LOTAHP's Avatar
Default Re: can i weld this (cryzko)
Is it your trailing arm with the dent or your half shaft with the dent????
Old 03-25-2004, 01:32 PM
Stewart's74
Stewart's74's Avatar
Wouldnt that cause the half shaft to be out of balance?
Old 03-25-2004, 01:39 PM
LOTAHP
LOTAHP's Avatar
Default Re: can i weld this (Stewart's74)
That's why I'm asking..... If it's the half shaft, replace it. If it's the trailing arm and you were to powder coat it, chances are the dent will not be that noticable. Chrome trailing arms :rolleyes: I can think of "LOTA" better ways to spend $$$
[Modified by lotahp, 1:40 PM 3/25/2004]
Old 03-25-2004, 05:14 PM
cryzko
cryzko's Avatar
it's the half shafts that have the dents.........
i'm welding the trailing arms and smoothin' them out....... does anyone think i'll have a problem having all my parts chrome dipped?...
thanks
cryzko
Old 03-25-2004, 05:24 PM
stinky
stinky's Avatar
No, but....why?
Old 03-25-2004, 05:25 PM
stpman
stpman's Avatar
I would think that if you weld dents in the shafts you are going to put them out of balance. How bad it would be I don't know,, if it was me I would either replace them or at the very least have them balanced.
Steve :steering:
Old 03-25-2004, 10:41 PM
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
Default Re: can i weld this (stpman)
If youre going to spend the money to chrome them, have new ones made...
Old 03-25-2004, 11:12 PM
comp
comp's Avatar
Default Re: can i weld this (427V8)
chrome imbrittelment (spelling) if it isn't done correctly part can fail, i know
someone out there can explain it correctly, i can't Anybody???
Old 03-26-2004, 01:51 AM
cryzko
cryzko's Avatar
i thought the same about the brittleness of the chrome on the half shafts..... i know that they make a carbon fiber half shaft that looks cool..... i'm going to refinish the whole rear suspension and install an air ride suspension........ it's gonna be more of a cruiser/tricked ride than a resor...... i'm trying to be different i guess.......
cryzko :p:
Old 03-26-2004, 06:39 AM
comp
comp's Avatar
GrandSport put the carbon in his, man, the looks are worth the money alone
i forget a lbs. they droped but it was a fair amount. So my vote is powder
coat & carbon fiber shaft's :thumbs:
Old 03-26-2004, 06:44 AM
Twin_Turbo
Twin_Turbo's Avatar
Default Re: can i weld this (comp)
Yes, hydrogen embrittlement. Chroming high stressed parts is not a very good idea IMO.
To can i weld this
Quick Reply: can i weld this
