seat belt buzzer part #?
Does anyone have a part # for the seat belt warning buzzer that is under the dash on the passenger side of a 76? Is it available through any online sources? Yes it is a useless piece of equipment but I like every light lit, every switch working and all the buzzers buzzing!
[Modified by RedShark76, 12:22 PM 3/24/2004]
Re: seat belt buzzer part #? (RedShark76)
I don't think anyone produces these; I've looked. Mine is flakey too, and I need everything working liek you! I opened it up, and there are only a few electronic components, so I may just replace all of the components. they're just through hole soldering in.
I got mine thru "Lectric Limited" in California. I'm at work right now and don't have the phone number, but let me know if you need it and I will e-mail it to you! Good Luck :seeya
Thanks guys
But I am not sure what it even looks like. Mine was missing when I bought the car. That was the last persons solution to fixing a problem. Take the buzzer and the bulbs out ! If you can find that phone # please post it.
Is this the correct lectric limited ? http://www.lectriclimited.com/
Yes, That's the correct Website. Don't know why I thought they were in California? Just in case here's the number: (708) 563-0400 this is their Tech Support line just tell them what you need. I rewired my whole corvette with their stuff... Excellent! Good Luck... Anthony
No reply from lectric limited yet on a part #.
www.corvettecentral.com says to use their part #593031 Ignition Switch Lock Warning Buzzer as a replacement. What do you think?
[Modified by RedShark76, 8:51 AM 3/31/2004]
They look exactly alike, I wouldn't be surprised if they were the same. I would call Lectric Limited at the Phone Number above and ask them personally. You can also order it from them if you want to?
Good Luck, Anthony
Good Luck, Anthony
Lectric Limited said they could not help me out. I am going to go with corvette central suggestion. We will see what happens.
