P/S Pump Mounting Bracket?
I recently purchased a 78 Vette with a 406 Engine. The previous owner tossed out the P/S Pump and mounting bracket but luckly he left the cylinders and control valves in place.
Is the P/S Pump bracket unique to a 350 Vette engine or will it fit the 406? If the bracket is the same can someone who has a Hollander Corvette Manual cross over other GM models and year pumps and brackets which will work so that I can go to a "Junk Yard" instead of having to order through expensive aftermarket suppliers.
Thanks in advance for your help.
