Problem areas in a 78?
I have a 78 Vette, and a buddy of mine was looking for one about that age. he asked me what the typical problem areas were for that year Vette. I couldn't really come up wiht any except droopy headlights, or leaky t-tops if the seals were bad. Can you guys thing of some things to look for? I have tried and only came up with the couple minor ones I just mentioned.
Re: Problem areas in a 78? (vethead)
Frame rust around the rear wheels.
Leaky anything. Differential, trans, engine.
Bad wheel bearings are a possibility, especially if mileage is high.
Our brakes LOVE to leak. :D
-Steve
-Steve
Re: Problem areas in a 78? (Pacin'California)
-Steve
-Steve
[Modified by vethead, 2:33 PM 3/22/2004]
Problem areas are not that much different from any year shark (except the added pollution crap and vacuum lines). A suggestion would be to read throught eh links below. Some here already mentioned some key things to look for, but there are many.
I always suggest (as do others) to buy the best you can afford, and have someone in the know to look at the car first.
http://www.corvettefaq.com/c3/dpg/part1.htm http://www.corvettefaq.com/c3/dpg/part2.htm http://www.corvettefaq.com/c3/dpg/part3.htm
[Modified by 78Vette-SA, 10:26 PM 3/22/2004]
I concur with what has been said.
many problems are typical C3 problems.
[Modified by LesTalent, 1:22 AM 3/23/2004]
Re: Problem areas in a 78? (KENS78SILVERANNIV)
The biggest problem I have is.... finding the time to drive it.
:cool:
:cool:
VetHead:
I kind of like Ken's response! But also believe it is dependent on part of country, mileage and care over 25 years. You can find them rust-free but as pointed out...brakes and bearings will leak as much as overuse as underuse. These problems are fixable...rusty frames and windshield surrounds are fixable but troublesome. High-mileage cars will have more mechanical problems and that includes, starter, alternator, motor, compressor, etc.
but the bottom line is you get what you pay for and so examine closely. I come across low-mileage original cars but they tend to be pricey. If you enjoy working on them, you can shop around and get a deal that you can bring back to life and get much satisfaction. Good luck
