Captive belt P/N
Captive belt P/N
For those of you who use the captive belt that goes around the water pump and crank... This belt is a real PIA and if it isn't perfect in every dimemsion it will not work. I finally found a perfect size.... believe it or not at Advance auto by cross referencing the OEM number. The one that is perfect is Dayco 15320. It is the correct width and is not a cog type belt.. Cogged belts don't work very well with the A/C tensioner because it pushes the wrong direction and actually breaks the belt at the cogs very quickly.
