Is there a way to reform weather stripping. T-tops
St. Jude Donor '10
Re: Is there a way to reform weather stripping. T-tops (Budman78)
Mine did the same!!
Next time I'll take the t-top pad off, and remove the two pins (or whatever you call them that go into the T-bar) and put the top back on then install the pins. I also heard to put powder on the t-bar so they would slide on easier.
Any other suggestions?? :confused:
Cruise-In VII Veteran
St. Jude Donor '07
I see why one of my t-tops is all jacked up. It looks like the weather stripping over the t bar is not flat. Instead it is compresses vertically. How can I flatten it out?
Hope there is - as when I changed the weather stripping the t-tops were not exactly aligned and the rubber set in that manner. Now no matter what you do the alignment seems not to take.
Re: Is there a way to reform weather stripping. T-tops (bigvette1)
I had the same issue. I removed the t-top. Added some additional weatherstrip adhesive and clamped it flat for several hours. I clamped the stripping down with those little plastic spring loaded hand clamps. They have rubber feet so I wasnt worried about scratching the paint.
This worked for me.
When complete, use lots of weatherstrip lubricant so the strip will not get hung up on the chrome.
This worked for me.
