Alarm in my the CAR???
I've purchase 1975 Vert convertable last December, it has after market alarm. One afternoon after driving the car a wird sound came on is not the after market alarm, it sound like a horn comming from the rear under the bumper. I traced the where it comming from there is a horn under the driver side rear close to wheel well. So I unplug the wire to keep it quiet. I had drove the car couple of times did not expirience that sound. Was that the factory alarm? If so, how can I disarm or disable it?
Re: Alarm in my the CAR??? (bluebelVETTE)
If everything is working correctly it should be enough with turning off the alarm through that switch.
Re: Alarm in my the CAR??? (gliot1)
The keyhole on the front driver side fender did stop the alarm, but when I turn it on the comes on right away without opening the door. What switches or relay that activates/turn on the alarm?
