My Harmonic Balancer completely let go and now can spin freely-any other damage done?
Today I was returning home from a very brief cruise and while accelerating mildly in 3rd I heard a pop. It sounded almost like something let go in the suspension. Since I wasn't sure what it was but was a couple of miles from home, I proceeded home cautiously listening for strange noises. I heard a few, but nothing too catastrophic, so I proceeded on home. When I got it in the driveway, I shut it down and I could really hear the clanking. I popped the hood and quickly noticed that the outer ring of the balancer had come completely separated from the inner piece. There is no sign of any of the rubber at all that once was between these two pieces. It now spins freely and can move back and forth several inches between the timing cover and the lower pulley.
Obviously, I need a new balancer.
Is it common for one to let go in this fashion? I mean, there was no warning at all.
Also, do you think that I could have done any damage to the crank or bearings with the balancer clanking around down there for a few miles (no high RPM's). I got 1500 miles on this motor, so I hope I have not put a hurting on the bearings. I know it has put some nice marks on my new timing cover.
Chris69 has offered to help me fix it. Looks like the car is going to be parked a while because I do not have time to fix it right now.
I am going with a stock type model and not the FluidDamper or anything. Should I go with a GM or some other brand?
Re: My Harmonic Balancer completely let go and now can spin freely-any other damage done? (hudman)
that happened to me once. Its not going to do much damage at all for the short time you drove it. Just don't drive it until you replace it.
Re: My Harmonic Balancer (GDaina)
, drove a week without any adverse affects
Wouldn't chance it with a new engine.
St. Jude Contributor
Re: My Harmonic Balancer (turtlevette)
Replacing the balancer is really a pretty easy job, shouldn't take more than a couple hours even if you're as pokey about it as I was when I did it.
BTW, Hudman, if you want the homemade tool I used to draw the new balancer on, I'd be happy to send it on. I don't forsee needing it again. Definitely easier on the new balancer than banging it on with a hammer.
JB
JB
Re: My Harmonic Balancer (JB)
Thanks JB. AutoZone has the puller and installer here that can be used. It is right down the road. You don't even have to buy the part from them!
Which dampner did you use when you changed yours?
Re: My Harmonic Balancer (hudman)
This one: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468522464
It was cheap and virtually identical to the original. Fits and works perfectly. There's a guy who will rebuild your original for you, and my intention is to send mine to him when I get around to it and switch them out.
JB
JB
