Poly. vs. rubber body mounts?
Old 03-19-2004, 12:35 PM
vetteboy1976kr
vetteboy1976kr's Avatar
Default Poly. vs. rubber body mounts?
I need to replace both #1 body mounts (especially since I have the front end off). Any pros/cons on going with the poly mounts over the rubber? The poly set is $79 with a new bolt kit, where the rubber set is $139. I know rubber is original, but $$ are tight. Any thoughts? I am looking at the kits from Eckler's.
[Modified by vetteboy1976kr, 12:36 PM 3/19/2004]
Old 03-19-2004, 03:12 PM
JBR
JBR's Avatar
Default Re: Poly. vs. rubber body mounts? (vetteboy1976kr)
I am no expert at this but this is what I have heard. Poly will give you a much harder ride, also how long will they last, there is no real data on that. They have not been around that long to know. One thing we all know is that the original rubber ones have lasted 25+ years and thats not bad. :cheers:
Old 03-20-2004, 01:16 AM
loose nut
loose nut's Avatar
Rubber. Anything you can do to add comfort and ride quality is money well spent. My car rides nice now with new rubber mounts and I am so happy I spent the extra $$.
Old 03-20-2004, 05:00 PM
Richard Cooper
Richard Cooper's Avatar
I replaced all my body mounts last summer with the rubber kit. :cool: The ride is great now. I bought my body mount kit from a local corvette shop for 141.00. They suggested that I use the rubber because it will give you a smoother ride. What the heck my vette is an 81 so the mounts were 22 years old.
Old 03-28-2004, 03:20 PM
LENNIE
LENNIE's Avatar
I am 60% progress on a major body off resto. and spared no expense. I choose to use poly because I believe it helps strengthen the body structure. also lasts longer. I bought rubber before and after a few years they start to crack and split at the surface. My idea is performance not so much comfort!!
Old 03-28-2004, 05:22 PM
78 Vette
78 Vette's Avatar
Default Re: Poly. vs. rubber body mounts? (LENNIE)
go with rubber the poly bushings always creek. I have theme all over my vette and they drive me up a wall. :banghead:
Old 03-28-2004, 10:48 PM
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
Default Re: Poly. vs. rubber body mounts? (78 Vette)
Poly is for Wusses.
real men use solid Aluminum!
(stock on a '69 ) :smash:
To Poly. vs. rubber body mounts?
Quick Reply: Poly. vs. rubber body mounts?
